My Domino flip-stop-amajigger
Scorpion
Was considering the recent OTT for my Domino and necessity encouraged me to do with what I had laying around.  I needed to find an easier and more accurate way to locate dominos on cabinet spreaders like in the below base.
The spreader (is what I call them) have two dominos that align them to the sides and only one allows the edge for a reference.
So I used an incra t-trac plus and fashioned a stop which reference to one edge.
Used woodpeck stops to reference the domino in the inner cut.
Worked very well.
Here's a side by side with the make-shift first version and my final version.  The final was made using an incra t-track plus for more rigidity and so festool clamps can clamp via the additional channel from the bottom.  Stop in the final is a piece of 3/16-inch aluminum angle.
Works well and cost about $40.
Never even occurred to me if it's been done before.  If it has, kudos to the other guy who I think like!
Nice!
I might have to steal your implementation. [emoji41]
Looks really good and useful.
Perfect would be, if it was able to break down and fit into the Systainer with the Domino. [emoji57]
grobkuschelig said:
Nice!
Hmm...don't see why it couldn't be like the OTT and be in pieces that you can connect to make a bigger piece.  I figured I'd hang it on the wall (I'm a home project guy not out in the field).
