PreferrablyWood
- Sep 8, 2013
So here goes what I'm going to be ordering instead of the Systainers because Neeleman got me thinking so I'm now replacing my Metabo 80mm with the Festool R0 90 DX.
I see the main advantage of RO 90 DX over my metabo 400 SX E as being:
A wider range of high quality abrasives available.
The rotex mode has faster more aggressive removal stock and paint removal.
-->(which at first I thought it was a pure rotary mode but after I watched the WoodWhispers video I now realize it is not quite as aggressive as a pure rotary mode as it combines the random orbit with a slower rotary mode, this is still much more aggressive than pure random orbit though..)
The Delta pad oscellation mode for getting into corners etc, which is still very effective, and HalfInchShy points out that the pure oscellation mode can also be used with the round disc as well..
The additional thin Delta head for doing Louvre Slats or other things in tight spaces..
The edge guards which are unique and prevent damaging moldings and calking very smart idea!
The interface pad for sanding contoured surfaces.
The Hard and Soft choices for both the round and delta modes
The polishing pad.
So all these things add up to making the RO 90 DX into a total system for sanding smaller items and working in tight and awkward places..Even though somewhat expensive for a smaller tool and perhaps not that well suited for larger surfaces, it does not worry me as I have the Festool RS 300 EQ, as well as the Metabo SXE 125 mm RO sanders that can do larger surfaces. So I end up with a very well rounded sanding arsenal with these 3 sanders..
My List then for this month ends up being a little more expensive than I was planning when I was just getting my systainer organization setup, but I am confident that it is well thought out after extensive research, the Systainer Organization setup can perhaps get a few tweeks and can wait until I've taken care of a few other things in December and January..
ROTEX RO 90 DX FEQ-Plus
Artikel-Nr.: 5718191
444,96 €*
Festool SYS-Roll SYS-Roll 100
Artikel-Nr.: 498660
105,99 €*
The SYS-Roll is the only remnant of my previous list, it's my insurance policy for getting my gear back and forth to the workplaces I'll be visiting in the next couple of months, and I don't want to leave gear on site but will be returning home with it everytime after my sessions.
Festool Granat Ø90mm P40 (50 Stück)
Artikel-Nr.: 497363
16,45 €*
Festool Granat Ø90mm P60 (50 Stück)
Artikel-Nr.: 497364
15,33 €*
Festool Granat Ø90mm P80 (50 Stück)
Artikel-Nr.: 497365
14,65 €*
Even though two posters advised against going with the 40 Grit, I think I'll get it as it's not prohibitively expensive and I'm getting 60, 80, 120 grits as well so should be able to handle any scratches the 40 grits might cause.. It might not be right for this application but I don't want to discover that I might have need it after all and miss the possiblity of using it.
The Delta mode sandpaper I start at 80 gr, and will prep for paint to 120 gr.
Festool Granat 93V P80 (50 Stück)
Artikel-Nr.: 497392
12,44 €*
Festool Brilliant 2 93V P120 (10 Stück)
Artikel-Nr.: 492881
x2 - 3,95 €* - 7,90 €*
Festool Brilliant 2 93V P180 (10 Stück)
Artikel-Nr.: 492882
2x 3,95 €* - 7,90 €*
I will use the RO 90 in Delta mode for sanding between the two coats of paint so the P180 should be fine and Brilliant is fine for this application I save by being able to just by 20 pieces at a time..
Festool Brilliant 2 93x178 mm Schleifblätter P40 - P400 P120 (10 Stück)
Artikel-Nr.: 492909
x2 - 5,21 €* - 10,42 €*
Festool Brilliant 2 93x178 mm P180 (10 Stück)
Artikel-Nr.: 492910
I need to have some abrasives of the RS 300 EQ as I'm doing some larger doors..I already have 40 and 80 gr, so I'm well suited for these jobs with these additional grits..
Festool Selfclean Filtersack SC-FIS-CT MIDI/5
Artikel-Nr.: 498411
18,95 €*
I'll be using my CT MIDI getting low on bags, so this gets on the list!
The polishing pad.
444,96 €*
Artikel-Nr.: 498660
105,99 €*
Artikel-Nr.: 497363
16,45 €*
Artikel-Nr.: 497364
15,33 €*
Artikel-Nr.: 497365
14,65 €*
Artikel-Nr.: 497392
12,44 €*
Artikel-Nr.: 492881
Artikel-Nr.: 492882
Artikel-Nr.: 492909
Artikel-Nr.: 492910
Artikel-Nr.: 498411
18,95 €*
