My new folding workbench - I'm after some feedback!
Well done. Looks great and very practical.
So mark me down for interest in plans, CNC cut files, etc, even kits if shipping overseas is reasonable - which I doubt due to weight.
Cheers.
Svar said:
Coach.carpenter said:
Svar said:
P.P.S.  A delux version could have t-slot extrusion along front and back
Ah ha i was waiting for someone to say this. Im working on it. So the two long top rails front and back have 3 8mm holea drilled in them. This is fora t track to be bolted in. I have a 25mm section of birch ply with a ujk t track mounted flush to the top. It also has captive nuts in. It gets fixed to the sides with 3 (6 altogether) m8 plastic knobs.
Two things im working on. The t-track isnt long enough so im desperatly trying to find longer extrusions. Secondly and rather stupidly, i made the back of the tooltote too high so it wont slot on with the t-track fixed. Easy fix and i need to ammend the drawing
Do you have 80/20 extrusions available in your area? Bosch-Rexroth makes nearly identical extrusions, could be easier to find in Europe. You could size your top overhang accordingly to easily mount/dismount the extrusion as on pics below. Would solve vertical clamping issue. Anyway, very elegant design you have there. Would not want to ruin the simplicity.
I like that idea a lot. is that 80/20 extrusion 80mm x 20mm? if so I may be able to make that work. I don't want it to effect the functionality of the mounting holes. As you say I don't want to take away from the simplicity as I believe when things get to finicky and fiddly they just don't get used when out on a job as time is money.
Cheers.
thylaxene ,
I have very good connections with Australia, where abouts are you? I lived and traveled there for twelve months. There is a real possibility i could get a kit to you if you are really that interested.
Coachy
luke1984 said:
looking good be a great addition to go with my mft.
Luke, It would be great for a side by side comparison actually to see what your thoughts are. It's measured 900mm high which i believe is the same as the MFT3.
Coachy
Looks great! No river dance ? (Just kidding)
How does it handle on an uneven floor or outside surface ?
Another thought: add rubber padding on the feet. Might help prevent movement while planing + moisture barrier.
Haha i like that comment! As for uneven surfaces you have two options. I like to keep things simple so i just rotate the bench until its solid and if not i use hardwood wedges to even it up. I may make attatchments with leveling feet but in all honesty i like simplicity when im on a job and pratting around with turny feet is too much for me
neilc said:
Nice work.  Did not realize the outside pieces were all hinged together, which makes it MUCH easier to breakdown and assemble.
Yeah if i wasnt walking back and forth its about 15 seconds. Im developing a system which will hold t togwther all as one unit now. Carry it as one then put it together qhen you get to your setup point
Holmz said:
What are the spoked wheels on? An MG?
Close and well spotted. Theyre off a triumph tr4. Cant remember the exactly year but mid 60mid anyway. I wish it was mine, i have driven it a couple of times and it drives like something from the 60s...
Like it! Would stop any splittingdown the ply too. Not that ive had a problem yet but best to be safe
Wooden Skye said:
Thanks for the videos, that is a great design and looks very stable.
Thanks, i appreciate the compliment. As for the videos theyre only quick demos. I have had comments on another forum about it not feeling like a premium product. What are your thoughTs?
Yeah, and right away, they picked up the lumbr to copy it.  But coscience was clear as it "was not a premium product."
Tinker
