Thank you all for the info! It was very helpful.
1. Will have to replace the cord attached to my hose with the new one from the saw. I am planning to put a flexible cable leave around anyway, so extra work but hopefully one more time only.
2. Probably will not go to get another larger hose. Especially that then i will have issues with the connectivity to my smaller tools,
Overall, I feel that Festool should standardize better for both of these - initially go with smaller gage cord for all tools as well with larger hose. It is clearly higher cost, but with Festool’s prices should be covered.
3. I use the splinter guard permanently and the spray seemed to come from the side window needed for blade replacement. With blue tape over it it is MUCH better, although I still have some accumulation in the front of the saw where the angle setting is located. Actually, I saw several YouTube videos where that opening was taped. I wonder why festool does not offer a cover for that opening as a standard equipment. I will try the “skirt” tape approach to check if this will improve the situation and then decide on permanent solution.
Thanks again!
BG
