I bought a used TS55 a few months back, but didn't have an opportunity to use it seriously until today.
I have a 14" wide panel that I have to crosscut to size. It is too wide for my miter saw and too long for my table saw.
I tried just laying the guide rail down on it, but it moved as I was cutting; it needed to be clamped.
There is no obvious way to clamp it without buying their $32 clamp, so I put another 14" panel down next to the panel to be cut and put the guide rail across both; got it square to the panel I need to cut, and clamped it to the second panel. Made my cut and found the cut wasn't square; it was off by about 1/20" over 24", or about 0.15 degrees. Not much, but enough to be obvious.
I assumed my set up was careless, so I tried to do better. Exact same result.
Did it again, this time checking to make sure the guide rail was still square to the board after making the cut; it was, but the cut was off by the same 0.15 degrees.
Did it twice more, each time with the exact same result. Well, at least it is repeatable.
All I can figure is that the back of the guide rail isn't square to the track, but it isn't damaged and I assume their quality control is better than that.
I tried to measure the width of the guide rail, but between the plastic strip and the rounded extrusion I really couldn't measure it to that precision.
Any insight into what is going on? I can probably compensate by having the guide rail off square by a hair, but that be the right solution.
