new 6" rotex feq dust connection to non festool ridgid hose
Bigred30
Does anyone know what connector I'd need to connect my new rotex 150 feq to my normal sized ridgid shop vac house? Preferably, one that swivels?
Rockler sells a dust right kit. It's about 25 bucks for a hose that hooks up to festool and directly to a regular shop vac. It isn't anti static but works very well, and it swivels.
It won't adapt to your ridgid hose but for about $35-40 the Bosch VAC005 is a non-anti-static hose with an ending that will work with most Festool tools and plug into your Ridgid vac. It doesn't have the lock on the vac end but it's a good friction fit.
I also recommend VAC005
I also used that Bosch hose with a Ridgid vac and it does work well. Then I got a CT26, so I put a Festool 36mm end on the Bosch hose and use it sometimes with my routers and my TS55. The Bosch hose is 35mm but has a 27mm hose end on it. The Festool 36mm end fits it perfectly so you can still use it if you upgrade to a CT at some point in the future.
