pettyconstruction
- Oct 17, 2010
So the boss (wife) wants a new cabinet door look.
I have a early 80’s style door , where they put a raised panel over a thin plywood center. What they did is cut a shallow cut in the panel to create a “bead board “ look.
What my question is , how do I retain the outer frame while changing the inside ?
Is there a router bit that can cut a slot and replace the panel?
Oh, the original panel was just nailed or glued to the inside of the door frame btw. Not “floating”.
Thanks in advance ,
Charlie
Thanks in advance ,
Charlie
