charliefreak
- May 30, 2020
I recently bought a new DF500 and used it for the first time yesterday. I’ve been practising, but I have some issues and I’m wondering if the group can help me decide whether this is technique, or whether I might have a faulty unit.
In all the videos I’ve watched the tenons fit snugly into the mortises (even needing a hammer tap to seat properly). But mine are too loose. I’m pretty sure I’m plunging straight without movement (I’ve used many biscuit jointers), and I’ve tried multiple cutters and tenons... all the same... a fraction of play - too much for a good joint.
My unit also vibrates a lot (if I set it down on the bench running it walks) and gets *very* hot. After a minute or two of running, the metal parts on the body are too hot to touch and I can see it melting the lube on the runners. I am using good dust collection, the fence is tight, and my stock is square.
What do you think is going on? I'd be grateful if other domino owners could let me know whether their units get this hot after cutting a dozen or so mortises (the bottom of the bearing / gear plate on the unit is too hot to touch), or whether their units vibrate this much?
Here are three videos illustrating the problem:
Thank you!
Thank you!
