Hi, I'm new here and to festool (three months or so).
1. I have a MIDI vacuum which I use with all my festools. There's a sticker near the receptacle that says "only connect tools rated 3.1 amps maximum to this receptacle." The problem is, all my other festools are rated >3.1 amps (TS55/10A, Kapex/13A, OF1400/11.7A, D500/3.5A). Should I not be plugging in those tools to my (festool) MIDI vac? Will it void the warranty if I do so? The other vacs all had similar amperage rating.
2. The laser on my kapex is out of alignment (already like that when I got it a week ago), the place where I bought it said it had to be calibrated by festool. I'm assuming this is incorrect and I can calibrate the lasers myself rather than send it back?
[attachthumb=1]
3. I've seen some people put tape over the small opening on the TS-saw where the arbor nut is, I assume this is done in order to reduce the dust coming out from that opening.
4. OF1400 sparking inside the motor during use, normal or send for service?
5. Last one, for smaller stock (like a 1x2), to get the best cut (straight and 45 miter) on the kapex, chop or slide?
TIA.
[attachthumb=1]
TIA.
