Mike S said:
yetihunter said:
And to the op, the grease that Festool uses can certainly seperate if the tool sits without getting hot for awhile. In that case, some oil will leak out wherever it finds it's way. No big deal.
That is good to know. I am expecting a call from Big Green tomorrow to see how they want to handle it.
Due to other reasons, I didn't get to try it out this weekend. I have pretty decent degree of confidence it is just fine. I was just surprised to see the schmoo in the box.
Issue resolution update: I cleaned the schmoo off of the sander and let it sit for another couple days. Big Green service called me yesterday and echoed the same diagnosis that [member=19475]yetihunter[/member] suggested.
Plugged it in, it runs fine. Will try to put it to use soon.
Interesting tool, but I certainly would not believe that this is a good tool for paint stripping that I feel that some folks said they were trying to use it for. Based on physical size, stroke, etc, I would suspect this is good for medium to fine sanding of preferably fairly bare-ish wood. I personally believe in the scraping method or heat and scrape for paint stripping, not trying to gouge it off with a sander.
I do know exactly what projects I will be putting this to use for, however.
BTW, thanks all, and special hat tip to [member=19475]yetihunter[/member].
