mino said:
				sebr023 said:
				mino said:
From this thread I’ve done every purchased wrong in the tracks length departement as well as connector! [emoji23]
They suggested to have a 800/1080, 1400 and 1900 as starter set.
They advice to buy the makita connector since they’re not destructive. So the set screws for the festool connectors leave mark/indentation in the rail? Should I return the festool connector? Is it still relevant since festool updated they connector design?
The new (self-aligning) festool connector is a very good design. Unfortunately, the 2nd one (not the self-aligning one) which goes into the top groove is still the denting type. This limits how one can tighten it without damaging the rail.
If you got the old set somehow (two same-lloging connectors) best try to return it.
If you got the new one, go and get one Makita set and play around ... it is cheap and bet you make your own calls what you prefer.
If you bought too many 1400 rails ... you can always cut one up to 600 and 800 and just get a 1900 KP one. I mean it seriously.
Oh! Yeah.
I read that in the thread posted. I was a bit surprised to know people cut their rail! [emoji28]
What would be the best way to cut it?
Using the other rail, upside down the one you cut, and go at it? Or on the miter saw?
I’d have to check the part number of the festool connector.
Also, what the hole in the LR32 rail used for? I’ve seen a bunch mentionning those rail instead of the regular one.
