ElectricFeet
- Feb 4, 2017
First post on this forum. I'm a sanding-newbie and recent Festool convert, with recent purchases:
I've always hated sanding in the past, and hence avoided it, but a few months ago I bought myself a Mirka hand sanding block with some Abranet, attached it to a vacuum and was blown away by how easy sanding has become. After a false start (thinking I needed a Mirka electric sander and Abranet discs) I then bought the RO 90 DX.
I'm now setting myself up to use it and need a range of abrasives.
Usage:
In the medium term, I know I'll be sanding some exterior metal railings (which are beginning to rust) for repainting; a wooden stool (to remove old light varnish) for oiling; and some painted interior doors for light surface repainting.
Currently have:
Questions:
1. I think I need a range of 90mm discs -- probably Granat, from what I've read here (and using the very nice abrasives search:http://www.festoolusa.com/abrasives ). Can anyone suggest how I might source these in small quantities? That is, around 4 different grit sizes, but just 10-15 of each? (My purchasing is Europe-based; mainly Axminster UK and Amazon UK/IT/DE. )
2. To get a range of 93mm deltas, I'm currently looking at these Mirka Abranetshttp://www.axminster.co.uk/mirka-abranet-delta-abrasive-sheets-pkt-10-ax872748 which sell in packs of 10 (I'd also get a backing pad to avoid any velcro depletion on the Festool end). Does anyone have any better suggestions?
3. Which disc grit sizes would you suggest for the jobs I've mentioned above? (Metal railings / Wooden stool / Interior doors and surrounds)?
4. Do I need Vlies for the metal railings, or will general purpose Granat manage it?
The abrasives search, while great, tells me what I **could** buy, as opposed to what I **would be advised** to buy.
Any help gratefully received!
- HKC 55 EB-Plus Li Circular Saw + rails
- RO 90 DX FEQ Sander
- OS 400 EQ Vecturo Multitool
- C 15 LI FL Screwdriver / Drill
- CTL SYS Vacuum
Usage:
Currently have:
- Discs: Mirka Abranet 120 / 360 and Mirka Abralon 600 / 1000 / 2000 / 4000, all of which I have cut to shape for 90mm disc;
- Deltas: Mirka Abralon 600 / 1000 / 2000 / 4000, which I have cut to shape for 93mm delta;
Questions:
