GoingMyWay
- Oct 11, 2017
Here's the video Stumpy Nubs did:
+1.derekcohen said:Snip.
5. The most important rule when sharpening is obtaining a wire edge for every stone. No wire edge means you have not honed the full face, and the result will be dull.Snip.
John Russell said:This is going to be a journey and I'm trying to make it as time and cost efficient as possible so I can use the tools and not be too obsessive about how shiny they are.
Thanks again, these comments have helped me to move ahead with sharpening and using my chisels.
ChuckS said:The effort one saves from using the ruler trick on the back of a commonly used chisel of 1" or narrower is small (none to me, because I sharpen freehand), when compared to using it on a plane blade. It may matter not much in general work, but for precision hand-cut joinery that shows (dovetails, through M&T, and whatnot), I'd only trust chisels honed in the traditional manner, without cutting corners.
