OF 1010 and OF 1400 Router Edge Guides
tk21769
Can the OF 1400 Edge Guide (FES-492636) also be used on the OF 1010?
Or is the rod size/spacing incompatible?
The Guides are different.  The edge guide for the OF 1400 is very robust.  I do not have an of 1010 so I cannot give you more details.
Dave R.
The one for the 1400 is larger and the holes are spaced farther apart....so no they are not interchangeable.
Best,
Todd
Ya, I can confirm this as I needed different adapters for my MicroFence system for the same reason.
Jim,
Do you use the microfence adapter for guiderail usage as well?
Eiji
No, I only use the MicroFence adapters, for the most part, for "circle" work, to-date....I originally intended to do some inlay banding, but haven't found a worthy project yet.
Eiji Fuller said:
Jim,
Eiji
I use my MicroFence on the Festool Guide Rails all the time for dados.  I gave up using dado blades on the saw a while back because rarely do I find dead flat ply, and consequently the dados would vary in depth.  Not so anymore using my 1400 and the MicroFence.  Expensive yes, but extremely accurate and versatile.
See reply number 6
