Gordon Bombay said:
Hey A-Aron,
I just want through the exact same decision as you (and sound like I am at a similar stage in the game). I ended up going with the 1400 after comparing the two of them. I actually just posted a review over in the other section of the FOG:
http://festoolownersgroup.com/festool-tool-reviews/festool-1010-vs-1400-beginning-woodworker/
That was a good review.
There are so many people polarized towards one or the other, whereas in reality either router is not a bad choice... However one really needs to run the paws over each unit, which is why I suggested getting the bits first.
95-99% of what the OP is doing is 1/4" or 8-mm territory. It is only if you are making 1-3/4" rail-n-stile doors where the 1/2" (on a table) becomes the required size. (Maybe some other stuff, but not a lot. Amana even makes the 1-1/2" sled bit in 1/4")
[member=48783]Gordon Bombay[/member] 's post adds further insight (or confusion
) that can only be sorted out with some time on the machines. Maybe someone in your area has one or the other or both and you could do some routing?
Also what his post implies implicitly is that neither choice of router is bad.
