s1301950 said:
I'm trying to zero out the router. Done the knob. Now I have to zero out the depth stop.
Sounds like you got it to move.
Zeroing the depth stop is simple:
1) Release the lever, push the machine (not switched on) down to the surface (so bit makes contact with the material), lock it
2) Release the 'knob', push down the metal rod onto to lowest of the pistons on the revolver
3) Push down the plastic tab till zero on the scale
4) Lift the plastic tab (including the rod) to the desired depth (on the scale), then tighten the depth stop clamping lever
5) Release the lock to deplunge the machine
Ready to go. Repeat procedure when you want a different depth or change the drill bit.
When you now plunge with the machine running you'll end up the depth you dialed in in step 4, you can fine adjust with the green dial near the lever (without releasing the lever). Dial the higher pistons (highest where the bit goes into the material, then down till you're at the lowest) to do multiple shallow passes instead of just one with the full final depth.
