Mario Turcot
- Nov 26, 2017
Hello all,
I never use a guide bushing before and I need some guidance. What template guide you guys would use to bore a 20mm hole. I have the 24mm template guide, the inside diameter is 21mm. Is that too close? Should I use the 27mm instead?
I want to make a jig/template using my CNC (32"x 32") so I can make MFT tops using the OF 1400 and a template guide but before I need to know the size to use for the CNC. The CNC will make the holes so the template is a tight fit
Your thoughts?
Thanks!
Your thoughts?
Thanks!
