magnuswyze
- Feb 23, 2022
Hello,
I'm an OF 2200 newbie (or Festool router for that matter). I have been using my Bosch 1617 for many years and last week I finally pulled the trigger on the OF 2200.
For its first task, I routed a through slot 2"x1 1/2" in size in the middle of 8/4 oak with Whiteside 1/2" diam upcut spiral bit. I'm quite satisfied with the feel and the experience.
One thing that I cannot figure out though was how to properly use the turret stop to mimic what I normally would do with my Bosch. On the Bosch 1617 turret stop, it has 8 steps with 1/8" distance between the steps. This allows me to quickly and safely route and take off 1/8" at a time. So for example, to route to a total depth of 1", I only need to setup once and use the stops to route 1/8" at a time. However, on this OF 2200, there are only 3 steps where the distance between them can be adjusted to my liking. Even if I adjust the distance between them to 1/8", it seemed to me I could only do a total depth of 3/8" before I need to reset and setup the depth again 2 more times so I can get to 1" total depth.
Is my above understanding on how OF 2200 turret stop should be used? If yes, is the reason for only having 3 steps because the OF2200 is so powerful that it's ok to take out oak 1/2" deep at a time?
Please kindly share your experience or trick on making multiple shallow cuts (or is making shallow cuts not needed for OF 2200?).
Thank you
Michael
Thank you
Michael
