John Stevens
- Jan 16, 2007
I've had my OF1000 about three years and it's a real gem.  However, when using it to bore 5mm holes for shelf pins, the pins always fit very loosely.  I thought it was because I was using cheap pins, but I just got some nice, brass pins and they also fit loosely.
I recently bought a 5mm drill bit, so I bored some holes with that, and the pins fit nice and snug in them. So it doesn't seem like the pins are the problem.
Finally, I put a 1/4" Onsrud spiral bit in the OF1000, bored some holes and checked them with a 1/4" drill bit and a 1/4" transfer punch--a little loose, just like when using the 5mm bit. So the problem doesn't seem to be in the bits.
As far as I can tell, the armature (or whatever you call the thing that the collet screws onto) has no play in it, and the collets are nice and clean and hold the bits securely.
Is there a problem with my router? If so, is there anything I can do about it?
Regards,
John
Regards,
John
