Outside Dimensions of Rose Box for the Festool Forstner Set Box ? #496390
I have that box for my Centrotec HSS drill set, I think it's a generic box so the dimensions are probably the same.
198 x 114 x 44 mm.
Thank you both  :), I have the HSS drills Box to, so if it is the same box I con use that one as a template for my plans to include it in my self made systainer insert.
Ingo
Ingo
the box is taller... about an inch or so.... the centrotec kit currently being sold has
the HSS bits included.... and the pocket it fits into has a foam filler so a taller box
can be substituted.... that taller box is the one in question.
That is the brad point bit set and it has a shorter box than the forstner bits. Alex had the correct dimensions from my measurements...
It is the size 4A from rose with the outside dimensions 200 x 115 x 42 mm.
Both sets from Festool do have the same box.
Ingo
