Here is my parallel guides improvement. These clear acrylic plates improve stability (guides don't twist rail anymore) and usability. Scribed line helps adjust cut width.
I used M4 screws and die. Standard metric threads are finer than standard imperial threads. There are 1/4"-20 and M6 bolts (below). The same ratio is true for other "standard" threads. (It's another reason switch to metric
[attachimg=2]
VictorL
[attachimg=2]
VictorL
