A alice Member Joined Mar 14, 2013 Messages 116 Oct 2, 2013 #1 just bought parallel guides can not clamp rail at same time am i missing something
Sparktrician Member Joined Dec 4, 2009 Messages 4,668 Location The New River Valley of Virginia Oct 2, 2013 #2 I'm not sure why you'd want to clamp the rail when you're using the guides. [huh]
A alice Member Joined Mar 14, 2013 Messages 116 Oct 2, 2013 #3 how do you stop rail from moving on melamine then. the parallel guides don't clamp to material
A alice Member Joined Mar 14, 2013 Messages 116 Oct 2, 2013 #5 but then you cant remove material that easy. have to loosen guides. not designed the best
ajones Member Joined Mar 27, 2010 Messages 2,062 Oct 2, 2013 #6 no just the clamps,no need to loosen guides once set, they could be better thats a fact..
A alice Member Joined Mar 14, 2013 Messages 116 Oct 2, 2013 #7 I think I might have figured it out my self if take t nut off of guide I can slide clamp in. Thanks for the help
A alice Member Joined Mar 14, 2013 Messages 116 Oct 2, 2013 #8 My idea didn't work. Tried clamps inside of guides but to cumbersome to hard to move material in and out
A Administrator_JSVN Guest Oct 2, 2013 #9 As stated, the clamps will need to go on the inside of the parallel guides. You can see it in this video:
tjbnwi Member Joined May 12, 2008 Messages 7,381 Oct 2, 2013 #10 Use a Gecko clamp or the Rapid Clamp. http://www.tool-home.com/products/catalog/index.php?manufacturers_id=60&sort=3d&filter_id=1092 http://www.tool-home.com/products/catalog/product_info.php/manufacturers_id/60/products_id/7788 Tom may have both or either in stock. Holy sniglets, if you go to the second link, Tom has a video link on how to use the Rapid Clamp, I learned something new today (that he has the links up, not how to use the clamp). Tom
tiralie Member Joined Jan 26, 2010 Messages 3,614 Oct 2, 2013 #11 Shane Holland said: As stated, the clamps will need to go on the inside of the parallel guides. You can see it in this video: Click to expand... Great video! I recently got some Gecko's to lift some heavy windows 150 lbs + and they worked perfectly. Tim
A alice Member Joined Mar 14, 2013 Messages 116 Oct 3, 2013 #12 Great advice bought two gecko's today work great plus good for window installs and sealed units thanks guys
