paulhtremblay
- Jun 4, 2014
I am about to buy a Festool ts 55 track saw, a 55 inch track, and a vacuum for making cabinets (mostly out of MDF) for my house. A bit later I will compliment my setup with a Dewalt DW 745 table saw for smaller cuts.
I also would like to invest in some type of Festool system to allow for repeatable parallel cuts, and accurate 90 degree cuts. Originally I had planned on getting the parallel rails with extensions, and the table top, and making my own solid base. But then I saw the Festool video and realized the full table had tracks on the side that allowed for cross cutting. At the same time, I have read reviews (on Amazon, specifically) that note that the MFT3 table will not provide accurate 90 degree cuts each time. So my options are:
1. Parallel rails with just table top. Advantages: ability to make repeatable parallel cuts, and use quas dogs for 90 degree cross cuts. Base will be stronger than MFT3 base. Disadvantages: MFT3 top alone may not allow for repeatable, accurate cuts.
2. Full MFT table. Advantages: rails on table can be calibrated with care to get accurate, repeatable cuts. Disadvantages: lets a bit less steady. Narrow rips without parallel guides may be more difficult. MFT3 may not give complete accuracy.
There is an option 3, where I get the parallel guide rails and the full table, but I would like to avoid this if possible, since my initial investment is already going to be quite a bit.
