cliffp said:Peter, do you have a recommendation of what to use as a spacer? Would the MFT/3 fence be suitable? If wood, which type, bearing in mind the tendency of some to warp, be soft or have other issues?
Hi Cliff
The MFT fence would be great but I keep a piece of 10mm MDF cut specially for the job. My workshop does not suffer great changes in humidity and so stability is not an issue.
Just to update the possibility of the saw touching the Parf Dogs - The top (furthest from the operator) Parf should never be in the way of a TS55 - my new film will make this quite clear. The only time a Parf may touch the saw is at the start of a cut with very wide boards (from memory I think that is over 510mm for cuts across the MFT3 and 810mm for cuts along the MFT3 - again covered in the film).
I have just made up my best jig yet for cutting 20mm holes and it works brilliantly - it took 2 minutes to make and the holes are perfect - even if I say so myself!
