Tyler Ernsberger
- Sep 30, 2014
six-point socket II said:Hi!
A percussion drill like the PDC is not meant to drill into concrete, let alone reinforced concrete. It's for drilling masonry and most of the time, thanks to the CE-Stone drill bits and the 3800 rpm you won't even need to turn the percussion mode on. The percussion is great for hard but rather brittle materials to minimize damage - where a rotary hammer would simply be too powerful and cause a lot of "collateral damage".
Quite a couple of modern masonry/materials even must not be drilled by using any type of percussion/hammering mode because it would cause too much damage inside the bricks (with hollow chambers) i.e.
If it's concrete or reinforced concrete - use a rotary hammer. Don't torture a percussion drill through it, it will simply die at some point - nothing gained except a few holes - that would have been drilled better and faster with the right tool.
6" hole saw will kill the PDC. I've taken mine up to 2.5" (6X mm) in 0.7" thick, massive, oak hardwood flooring, that works if you "listen" to the drill and have a feel for what you are doing. I don't see myself using the PDC for larger hole saws - there are way more suited/ speciality drills for that.
Kind regards,
Oliver
For what it’s worth on the Festool USA web site it says that the PDC is designed to “blast through concrete”. From my experience it’s not a good hammer drill/ percussion drill. Every other high end cordless brand that offers a “hammer drill” can drill through concrete. It’s still a great drill but I don’t use the hammer/precusion mode bc it’s worth less.
