Mettes
 - Mar 14, 2008
Hello,
Well then Friday there was a demo/special offers day at my hardwarestore. Dewalt, Makita, Bosch, Hitachi, Fein, Spit/Paslode and of course Festool all had there demotruck or trailer parked up front, there were some beers and french fries, and a 5% discount on everything, so yes it was fun.
Festool had there not so new MFT/3 with them but also some more interesting stuff:
- vacuumclamp: it's powerful, and engaged automatically when a workpiece is pressed against, the footpedal is for disengaging, didn't ask if you could choose to engage/disengage with the footpedal.
- T12+3 and T15+3: there light, very light, there powerful, the torque control is at the back on the underside with a big dumpscrew, easy to use one handed. There is a switch to choose between speed 1 and 2, and a switch to choose between driver and drill mode. In drill mode to torquecontrol is not active. They will work with the old battery's, the charger will charge the old battery's, but the new battery's will not work on the old machine's. There will not be a new C12 with Li-Ion battery's, according to the Festool representative.
- There was a new Centrotec-set on display, with HSS metal drills up to 10mm, the drills where placed in a metal cardridge. There was a little ring included to put one the long driver-bits and is was magnetic to hold a screw, up to 1 kilogram according to the information provided. This gives you an indication of how powerful the new drill/drivers are... ;D
That's about it, just one other, non-festool, thing worth mentioning:
Fein will be releasing a new Supercut next year, with quick-change. The Fein representative could/would not say if the new Supercut would then use the same accessories as the Multimaster (now they have different holes).
Cheers, and if you have question, just ask...
