Sjur said:Oh, sorry, that wasn't what I meant to write. The garage is partly covered by my mother's apartment. However, the majority of the garage is covered by the patio.
It definetly gets cold in Norway, but water freezing in concrete isn't a concern at all. Concrete is a porous material, so if something freezes, it won't affect the concrete, as the water freezes in those pores. What makes concrete expand is if the rebar rusts. This won't happen here either, though.
I have been sceptical to the heating-method mentioned, but I figured if I ran a dehumidifier the same time as a heater, it would cancel eachother out. I have no knowledge of the humidity in air in Norway vs. Denmark. I guess it depends how close to the ocean you live. I live about 20minutes away. Having my garage dry and heated is of course preferable, but in the end, it all comes down to expenses.
Wow, I didn't know the electricity was that expensive in Denmark! The price definetly varies during the year (because we mainly rely on dams), but generally it's around that price. The subscription model varies, but we generally pay around 0,32NOK +30NOK/month.
Sjur
I don't understand where water into your garage is coming from if not thru the concrete. You say concrete is pours, so water getting into it and freezing is not a concern. That depends on the quality of the concrete. If there was too much water in the mix when the concrete was placed, and the concrete is exposed to the elements, water getting into the concrete and freezing can create a problem. If that water can get to the rebars, there will eventually be a bigger problem. When i was in mason biz, any time we had a situation such as you mention, we used vibration to settle concrete into a denser mix. There were additives we put into the mix as well that created a more dense mix when placed. I have been out of the trade for 30+ years so I don't know what additives are available now. But, if you are getting water from above, it has to be coming thru the concrete somehow.
Until you find a way to stop that filtration, you will continue to have problems no matter how much insulation and heat you manage.
Tinker
