I was looking at mobile benches today and discovered a company called Treston that make a modular height adjustable system that I think could work well with an MFT in any shop or site environment. The video below shows a static one but they also do the same thing on castors. The dimensions are perfect as all the benches are 700mm deep and come in a variety of lengths. They are also infinitely height adjustable between 650-900mm with an allen key. I'm sure the tops could be adapted for woodworking by bonding a thin sheet of HDF to them. They also do a compatible pegboard system.
I think the castor version could be the perfect solution for MFT users. You could do away with the legs and mount the MFT on top and then use a couple either side as extensions. They could also be used to make the perfect mobile mitre saw station with the middle table height adjustable to suit any mitre saw. They also supply a bottom shelf which would be the perfect place for your CT.
Treston UK Site
Cheaper Here
Treston TP workbench assembly instructions
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
Treston UK Site
Cheaper Here
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
