arso_bg
- Jan 6, 2008
Hi all
I have a large custom table which is build with the old MFT profiles. I have to say that I am quite happy with it and I don't plan to change it soon with the newer MFT3 table. The only thing that I always wanted to improve is the fence. Recently I had some more time to experiment and now I have a new precision fence installed on my table.
For my new fence I used a Festool "clamping profile" which is 1400 mm long. These profiles are sturdy aluminum extrusions with four "T" tracks and can be obtained in two different lengths - 800 mm and 1400 mm. I think they are not intended to be used as a fence but they have at least several advantages when compared to the original MFT (800/1080) fence:
1. The "clamping profile" is much sturdier
2. The 1400 mm profile is longer which gives you some extra cutting capacity.
3. If you need even a longer fence you can easily attach a second profile exactly as we do it with the guide rails.
4. The "clamping profile" has four "T" tracks
As a Festool product the "clamping profiles" can be combined with the most well known Festool components without any modifications.
