Frank Pellow
- Jan 16, 2007
2011, January 30:
There was a lot going on this week and, as well, I had intermittent electrical problems with my Festool Rotex 150 sander, so I didn’t make much progress on the hall door project. I did get the walnut attached to the back” side of the door and made a good start on applying the walnut to the doorway leading to the office.
One of the pieces of walnut that I attached to the door contained a soft crumbly spot and, in fact a small hole all the way through. But the rest of the piece was quite good, so I decided to position it so that the spot was right at the bottom and to attempt to patch the spot. I prepared a “putty” consisting of equal parts cyanocrylate glue and walnut sawdust, applied it to the spot, then, after a suitable wait, sanded the patch:
[attachthumb=#1] [attachthumb=#2] [attachthumb=#3]
The results of the experiment were somewhat mixed. The spot is now as strong and smooth as the rest of the wood but still very obvious and not at all natural looking. Here is photo of the bottom of the door after three coats of tung oil:
[attachthumb=#4]
I am glad that the spot is right at the bottom and assume that most folks will not notice it.
With that little aside out the way, I will carry on documenting the steps to construct and install one of these doors that I started last week:
(7) The back of the door was clad with 8.5mm thick walnut in a similar manner as described above for the front of the door. The only difference from the front is that the walnut on the back is placed flush to the window openings.
The walnut on both the front and back is slightly cut so that it is slightly proud of the door’s top bottom and side edges. On the sides, I then sanded it flush:
[attachthumb=#5]
On the bottom and top, I cut it flush with my track saw:
[attachthumb=#6]
[8] I decided to make very simple molding to hold in the windows and to attach that molding with brass canoe tacks:
[attachthumb=#7] [attachthumb=#8]
Of course, one can see the tack heads, but that’s in keeping with a lot of arts and crafts style furnishings.
A good thing about this trim is that it is easy to remove with no damage using a dull chisel:
[attachthumb=#9]
[attachthumb=#4]
[attachthumb=#5]
[attachthumb=#6]
[attachthumb=#9]
