I guess my workshop could be considered a "member project"....
Anyway, I'm in the process of building out my workshop and I'm trying to plan things. My Delta 50-760 (1 1/2 horsepower) dust collector is going in its own little room so as to not eat up space in my shop, which is why you don't see it on the drawings. I've done a very basic Sketchup drawing of what I'm thinking and wanted to get feedback. I don't have a ton of space so I want to make most efficient use of what I have.
My idea is to have a main "workspace". You can see that as the open area in the drawing. I'll have spiral pipe ran down the empty wall about in the middle so that I can wheel any of the big machines over and easily hook up to DC. When something isn't in use, it goes back in its place out of the way. I also want to try to avoid having to move a machine to get to another machine. I simply don't have the room or DC power to have multiple machines hooked up at once.
At this point, I'm planning to build the bench for the SCMS at the same depth/height as the Unisaw. Also, I think I'm leaning toward the MFT as a workbench since its collapsible and could be stored very easily....it seems like the MFT would fit good in my 'open space' when I need it and go out of the way easily when i need to use the big machines.
Oh, and the wall I left off the drawing will in fact be a wall...the entry door will be on that wall right next to where the A3-31 is in the drawing.
Feedback? Suggestions of what to do differently? All the machines will be on mobile bases, so rearranging them isn't a big deal. The main things I need to put in stone are where the spiral pipe will run to and the dimensions for the SCMS bench.
