PaulMarcel
matt.mackinnon said:Update:
I did get in contact with Festool after quite a few failed attempts. they are sending me a new plastic tool shroud to replace the one that shattered. So I think it will coat the inside with Fiberglass and Resin so that it cannot break as I know I won't want to replace this again.
Not a bad idea. Not knowing what the "fiberglass and resin" you plan, Bondo grey/gray would be perfect for this and is much cheaper than the pink body-filler. You wouldn't need a fiberglass reinforcement inside it otherwise my granite shower pan would have collapsed ages ago...
