Looking for suggestions - Recently I was attempting to cut 15" circles with a PSB 300 EQ Jigsaw with the trammel bar through
3/4" Baltic Burch Plywood. Started out with Festool 2" (50mm) blade P/N # 486564. Adjusted the blade Jaws as per on-line videos, started to cut,
was not in a hurry so I applied little pressure. With in 2" of the cut origination the blade started to bend "in" towards the center of the cut - not cutting perpendicular to the wood surface. Change bladed to a larger blade P/N 473723 which is a heavier blade, and tried to correct the cut, same problem - blade bent at a angle ?
At this point I tried a new blade but also tried checking the Jaws adjustment, that is when I was the "jaws" were deflecting the blade. The stationary side of the jaws is not aligned with the Blade Holder. You can look down the blade and see the blade defliction at the jaws. You cannot adjust the jaws with the small Allen wrench supplied with the saw - as the fixed jaw that is the problem
Any thoughts............
Tom R.
Tom R.
