Bugsysiegals
- Mar 19, 2016
rst said:Hey Bugsy...I'm glad to see someone else that was not satisfied with the stock fence arrangement. Although in my case I wanted the additional cross cut capability. I made model years ago using UHMW routed and screwed together, giving me 27 1/2" width cutting using the same Incra and have two stops. You'd is a much more elegant solution. The other thing I did was extend the fence with a piece of 3/8" aluminum so that short pieces are supported thru the cut. Also, routed the square cut line with dovetail slot so I could use another UHMW removable kerf insert.
Thanks!! It was two weeks of frustration as I continually adjusted the model so it fit snug in all areas while keeping 90 degrees to the surface. It feels like it snaps into place and doesn't need the knobs but I put them on just for safe measure. I've not cut many short pieces but when I did I put a longer piece behind the short piece to "extend" the fence ... It would be worth seeing what you've done!
