QQ about Parf guide holes + Veritas and TSO dogs
kitui
Hello, I purchased the PARF guide with 2 sets of small veritas bench dogs and the TSO tall bench dogs with the clips for the festool guide. I made a hole to see if the new corded drill could handle the process. I tested the hole and I noticed that the Veritas bench dogs snuggle perfectly but the TSO are quite loose. I was not expecting this outcome. Is it normal? Is it important? Probably not if all the holes are drill equally and equally distant and perfectly perpendicular. Please advise. Thanks
All:
when using the ParfGuide SYstem we now recommend using our new CT-Dogs. These Close Tolerance Dogs as the name implies are made to extremely close tolerances with a slightly larger diameter specifically for use with the ParfGuideSystem.
Our general purpose Dogs in our workholding line up are intended to be secured with Knobs from below to ensure their square alignment. They are intentionally made with more clearance to allow for the wider tolerances to which homemade worktops and the MFT tops are made. Close tolerances come at a price: namely its easier to encounter interference when all elements involved, especially worktops, are not machined to matching dimensions and equally tight tolerances.
More information and a no-cost exchange program for replacing the TSO  general purpose Dogs will be in a TSO INSIDER newsletter shortly. We already have the Small and Tall CT-Dog in stock. They will be on our website within a week.
Hans
Hans:
Are your CT dogs an improvement over the Veritas Parf Dogs?  Such that the resultant hole pattern is more accurate?
RustE said:
Hans:
we can't comment on Veritas Parf Dog tolerances.
We do know that our CT-Dogs will be an extremely good match for the Parf Guide System - money back guaranteed by TSO [smile]
Hans
TSO-Hans
I bought the Parf guide from Lee valley ( I do not think TSO had the guide at that time)  but the TSO long dogs and the clips from Bob Marino. Does TSO SWAP also the long dogs I bought from Marino? I followed another post that suggested long dogs with clips after drilling holes with the PARF guide. They were all defined as 20mm. :(
TSO is moving to produce the first batch of Stubby Dogs as soon as we can. Meanwhile, we will give some thought on how to make these available for customers who purchased the Tall Dogs from us and prefer the Stubby version instead.
Hans and Eric
Hans, FWIW I tested the non-CT dogs I recently received from you in parf guide drilled holes today and they fit perfectly. If they were any bigger I would have had to hammer them in.
My PG was purchased about a year ago from Axmister and has the old-style 20mm bit. Not sure if the new bits are slightly larger or ???
RMW
TSO Products said:
All:
Hans
[member=8712]Richard/RMW[/member]
your comment about TSO's standard Dogs fitting just fine with your top made some time ago with a ParfGuide Drill Bit is appreciated. You confirm our recent experience that there is a place for both Dog body diameters (as we try to explain on our website www.tsoproducts..com  and also mentioned in our latest TSO INSIDER newsltter.
By the way: we made a naming change on our Close Fitting Dogs to CF-Dog from  the CT- moniker we had planned earlier. It dawned on us that all our Dogs are made to close tolerances (duuuuh...) but the are made to different fits. So don't retire your TSO or other standard 19.9mm body diameter dogs. You will continue to find them appropriate for many tasks in the future - especially with knobs like our SpeedKnobs.
A couple of things we have learned to appreciate:
our Tall CF-Dogs work QUITE well when A "handle" is useful to pull them out of close fitting holes and especially when using them with the Parf Guide drill fixture.
Hans
Hans:  Are your close-fit dogs marked to differentiate them from standard fit dogs?
from TSO's website product page on the CF-Dogs:
So Exactly What's Different Here?
DoubleGroove CF-Dogs are distinguished by their slightly larger body diameter, 0.003" (0.08 mm) to be exact. While this change may seem minute, it makes all the difference in eliminating any unwanted play that may be present when a standard 20mm dog is inserted into a precision cut 20mm hole. A CF-Dog can be easily identified by the addition of a single annular groove in its top surface.
thanks for asking
Hans
Hans:  I meant marked for easy identification.  I don’t always have a micrometer handy.
[member=63201]RustE[/member]  -
I was unable to underscore the copied and pasted text from our website - last sentence above:
sorry about that
Hans
Hans:  My apologies. I read your last post too quickly. Thanks for the clarification.
Hans,
I received my CF Dogs today and the fit is spot on!!!! Can't wait for the CF stubbys.
Jack
Claimdude said:
Hans,
Jack
#Claimdude - feedback is always welcome on the CF-Dogs or any of our products. Jack, what type of 20mm worktop are you using -MFT/3 or?
Hans
Hans,
I have a custom MFT style work bench built with the JackBench concept. The top was milled at a pro wood working milling place on their CNC. The dimensions are larger than an MFT but the hole size were 20mm in the plans.
Jack
TSO Products said:
Claimdude said:
Hans,
Jack
Hans
I got the CF dogs by TSO and love them. They are much better fit for my Workbench top done with the PARF Guide (Love that one too) then the previous version. However, I still have not resolved the problem of the Tall dogs hitting the TS55 motor. If I knew that before buying them, I would not have bought the long dogs. I bought them to use them with the clip (genius idea) but there are too many limitation on the width of the stock that they are mostly useless for the clips. Did TSO come up with an idea with a medium dog that would fit (without getting the Superdog which is great but way to pricey)?
I think the next logical item to fabricate (TSO or UJK or whoever), is a dog clip with an offset wide enough to move the rail away from dogs which are too tall for motors or batteries on track saws to get by. Instead of making dogs all different heights which will get pretty silly after a while, just fix the issue at the actual connection point to the rail. KISS should always be the first pathway.
And when you make that, send me a royalty.
I am wondering if I can add another veritas dog on top of the first one and use the knob to keep them together, using the 20mm part of the second dog to lock the clip...I will try. May point was that when I purchased the tall dogs, they came with the clip and there was not disclosure that I could not use it if the dog was too close to the stock. Anyway, good idea. I will see if it works.
That was the beauty of the RMW rip dog clips...they connected/hooked on to the dogs with an offset so there was no interference with the saw.
