You only need one size dogs, about ~ 65 mm from the table surface (for TS55) to cover any size of material. This size dog will clear the motor housing regardless of the material thickness.bnaboatbuilder said:I think the next logical item to fabricate (TSO or UJK or whoever), is a dog clip with an offset wide enough to move the rail away from dogs which are too tall for motors or batteries on track saws to get by. Instead of making dogs all different heights which will get pretty silly after a while, just fix the issue at the actual connection point to the rail. KISS should always be the first pathway.
And when you make that, send me a royalty.
The only reason to have taller dog is for non-through cuts in very thick material.
