DavidCBaker
- May 31, 2010
I'm building a small box with finger joints. I was going to make the slits for the bottom of the box with several passes over the table saw rather than mess with a dado blade. I suppose I could use a router, too, set up on a guide rail.
But in either case, I don't know how I'm going to do that without having the slots cut into the inside of an individual finger...and then look silly in the joint. Does that make sense? In other words, I need to route or groove the sides up TO the finger joint without scoring across it.
Any ideas on the best way to do this?
I can post a picture if that helps.
