MikeGE
- Apr 7, 2019
I apologize in advance for asking what might be a stupid question.
I want to modify the vacuum lines on my VAC SYS for use with my new MFT-style workbench. I'll post photos later, but I have the vacuum pump on a pull-out tray, where it will remain most of the time. The SE1 will be attached to the side of the workbench when in use, and stored on a pull-out tray above the vacuum pump when not being used. The SE1 will be about three feet from the pump, so I don't need the long hose currently attached to it, as it just gets in the way. I will disconnect the vacuum line from the pump and can coil it around the SE1, but I can't disconnect the foot switch...yet.
I would like to add quick disconnect fittings so I can remove the hoses for easier storage, and also shorten the lines a bit. Ideally, I would have two sets of hoses, one for the workbench and the original hoses kept in the Systainer for those times when I take the VAC SYS out of my shop.
Can the same quick disconnect fittings used for compressor lines be used for vacuum lines? If not, which fittings are compatible with the VAC SYS?
