Hi all,
I have now completed 4 Sysports and 21 foot of clostets with the Hettich VB connectors and I must say it is very efficient and easy, even if you own a Domino, since there's no gluing and clamping involved. The best and easiest way to drill those holes (except for CNC) is this Hettich DrillJig VB and your Festool hand drill:
http://web2.hettich.com/hbh/Start.do?localeId=EN&itemId=20166
I tried two different jigs, but in the end I would really recommend the Hettich and the 150 EUR are well invested, especially if you have to drill 12 holes per closet body. I have not once made an error on the above projects.
The connector I would recommend is the nickel plated VB 36MD/19 for 19 mm thickness (or the 16 for 16mm). The M version is the one with mounting aid that puts the screw in dowel in the centre:
