Does Festool make a rail guide attachment, which we can attach accessories to?
Love my TS75 and rails....but tired of drawing lines, and cutting to the lines on full size sheets. Cumbersome, and the two steps is more potential for error...
A simple solution is a rail measuring guide, which attaches to the rail hump, then, on the other end, a parallel edge. A measurement scale lies between, such as INcra's. You cut a test piece, measure that piece, slide the measuring scale so it matches to the size of the cut, and secure the scale. Now its fine tuned to your saw.
Although I do own the parallel guides, and I do find them very useful at times, I don't like using them on my 118" rail making long rips. The rail is flimsy enough without the added weight of the parelle guides. I remove the rail from the sheets often. So I was thinking of a simple measuring system that "sets" the rail x distance from the edge, clamp rail, then remove the measuring sticks. Same premise as the parallel guides, except, easy on/off.
Any flaws in the concept? Or is one already made?
