Ras 115 disc
Chris3711
Hello I can not find any disc for my ras grinder/sander I mostly use it for scribing my trim so I looking for the lower grits like 40 or less. Has anyone found a alternative brands that works with this?
hi, tool nirvana has 40 and 80 grit in rubin and 36 grit in saphir you can also buy the fiberfix backing pad and use resin fiber discs from the big box or wherever. I think empire supply also carry a line of 115mm/4.5 discs
They only had two of the 5x packs in the 36 so bought those thank you so much. Let me know if you see any more.
