I own both the RAS 115 and the RO 150, and the RAS is quite a bit faster at stripping paint than the Rotex. But the RAS leaves an uneven surface that needs more sanding by a finer sander. This could be done by the ETS EC 150 and the DTS400. But the harder the wood, the longer it takes. A RO 150 would do this quicker.
So if you have both, the RAS would be the best choice for the stripping alone. But if you have to buy a new sander, the RO150 would prove to be much more versatile and be more value for your money over time. The RAS is a sander that you only use for the most difficult jobs, and lays on the shelf the rest of its life, while the Rotex is a lot more usefull for other jobs as well.
