Recommendations for cleaning Shellac finished table
ultane
I recently built a small table out of mahogany and maple for my daughter and son in law. I finished it with spray Shellac (rattle can) from Home Depot. It has a glossy finish that collects finger prints like crazy. What is the best (easiest) way to clean this?
I guess the first question is "what are you trying to clean off of it?
Second, I would suggest waxing it. This will make cleaning much easier in the first place and help with fingerprints as a bonus.
The Renaissance wax will definitely help with the fingerprint thing, that is kind of it's intended purpose.
It's a little pricey, but it works very well and you don't need much.
Thanks! I’ll look for it. Where do you get yours?
After seeing that Waterlox recommended Swiffer wet floor wipes for safely cleaning their Tung oil finishes, I now use those refills to clean all sorts of wood projects.
I used them to clean my oak kitchen cabinets recently.  They did a good job, smelled OK.  They are probably OK for your skin, but I wore gloves.
Since a lot of people keep a swiffer on hand for quick cleanups, this can be very convenient.  However I would definitely test first.  I have not tried this on shellac.
Note:  I did not use the mop, I used the clothes in my hands for this.
Hi [member=25208]ultane[/member]
I agree with the above but you could go a little further...
If any of the marks go beyond a smear on the surface then a quick wipe with a cloth which has a little methylated spirits (denatured alcohol) on it should take a very thin layer of shellac off. You could build up an oil finish or use a hard wax next. Leave a little time after applying the wax and buff vigorously.
@Peter Parfitt
I used denatured alcohol once, but I don’t want to continue to remove the shellac. Hence the question posed.
I get it from a local woodworking store, but Amazon has it too, for about $17.50
Id clean it with ever I usually clean furniture with then go over it with a nice coat of wax
