ibluetooth
- Apr 29, 2020
Hi everyone,
I'm looking to buy my first Festool Tool, along with others required to start my first wood working project. (lists of projects below)
Your suggestions are greatly appreciated on which tools would make the most sense to start.
I do have a couple of power tools from the Yellow Brand - including a cordless impact driver (DCF888) and circular saw (DCS575) + a couple of FlexVolt 9AH batteries. I've also got an older 12” sliding dual bevel compound mitre saw and a few of the Kreg tools I've accumulated over the years - K4 Pocket Hole Jig, Cabinet hardware jig, concealed hinge jig, shelf pin jig, drawer slide jig, square cut jig, multi mark tool. I should say that I'm not married to any of the tools listed above and would probably give them away to a family member if they were to be replaced by a Festool equivalent eventually. I'm also not really sold on the pocket hole way of joinery, but recognize that it's a workable solution while I build up the rest of the necessary equipment to get the first couple of projects under my belt.
With regards to workspace, I don't have a lot unfortunately. I don't see myself having a dedicated table saw or router table as the section of my garage where I'd be working is simply too small. The best setup for me would be a couple of saw horses that fold away when not in use along a with a 4 x 8 piece of sacrificial rigid foam insulation that can be tucked away behind a bunch of cabinets in the garage when not in use. I do have a couple of 55" tool storage work benches with bamboo tops that will provide some much needed work surface space for these projects as well.
I think the first thing I should invest in is Dust Collection - although I'm open to differences of opinion from the group and/or recommendations as to which dust extractor.
I do have a few ideas of projects that I'd like to complete including the following:
1. Patio Firepit Table + Concrete Top (Doubles as a family dinner table for 6 -
?itok=Bwat92K-) Will have to make adjustments to the dimensions to accommodate dinner plates and maybe use a DIY Concrete table top.
2. Patio Sofa and Chair (https://i.pinimg.com/originals/9f/29/b7/9f29b75a20d7e6ce1d7a2142b0a001be.jpg)
3. Bathroom Vanity (https://www.youtube.com/watch?v=4J6nMdlVBtc)
4. BBQ Cooking Station (still looking for ideas)
5. Built In Master Bedroom Closet (https://www.houzz.com/photos/melhorn-traditional-closet-miami-phvw-vp~89653522)
6. Live Edge Media Console (https://www.youtube.com/watch?v=McQbastKY14)
The reality is that I'm probably going to try and finish the Patio Firepit Table this summer. Depending on how well that project goes, I think the Patio Sofa and Chair may be completed in the fall and then the rest to follow later in the year / into next year and years to come. In terms of building material, based on all of the projects listed above, I can't see myself using any material larger than 2 x 8 joined together for table tops. The rest would probably be pre-finished lumber + plywood from the local home improvement store.
I look forward to reading everyone's suggestions. Also, I know some forums frown upon reseller recommendations, so can someone recommend where I'd find the authorized resellers near Whitby, Canada? I'm looking for a reseller that will be patient with a person that's new to woodworking and has the ability to help me understand what most of the lineup does and what's the most optimized for what I'm trying to accomplish.
Thanks so much in advance
