barnowl said:
Seriously, I can't understand why anyone would want to remove the pins.
They are so very important in registering multiple dominoes.
I'd suggest working on your cutting technique, as I find them invaluable.
There's nothing wrong with my cutting technique. But please, elaborate. Invaluable for what? If I am using dominoes to do a long section, using the pins to index one after the other seems to me to be a waste of dominoes.
On that we agree. I'm referring to multiples in shorter glueups, registering the 1st domino with the pin from the edge, and the 2nd from the 1st.
For short sections, I bought the self centering jig mentioned above, which seems to me to be much more versatile, even if it is a little slower than some other techniques.
My reference to cutting technique was because some have said that they felt that the pins "seem to push the tool from the work".
I haven't found this to be the case at all, holding the fence tight with one hand, and the other hand gently feeding the tool.
And many times I use pencil marks, but I find the pins one more option depending on the application.
I did buy the magnetic discs for smaller stock, but not the self centering jig.
