ear3
- Jul 24, 2014
I'm making a series of plywood office dividers, and stumbled across a decent solution for doing repeat mortises. The basic precondition is cutting the boards square. Then the mft hole pattern, a mix of qwas and parf dogs, and the 2000mm mfs profile do the rest. I had some leeway on the height of the fixed shelf, so I was able to just use the hole pattern as given, plus the different width of the qwas vs parf dogs, to set the position of the mfs extrusion. If I needed the row of mortises to be at a precise height, though, then I could simply cut a wooden spacer to slide in between the end of the board and the dogs. Once the mortises were plunged on the first board, I simply slid in the others and repeated the operation. I put pencil marks on the extrusion to mark the position of the mortises so i wouldnt have to measure every time. Super fast and precise.
