Curt said:What is your method for dealing with repeating thin rips - as in cutting face frame pieces from a stick of hardwood?
Curt said:Guys - I realize the table saw is the perfect tool for this particular task, but I sold mine. It's been replaced with the combination of the MFT/3 and a 17" bandsaw. I needed the space and I can fit both these tools in the space occupied by the TS with 36" rails. My intention is to move into the handtool world as far as I can. It's just that ripping hardwood by hand is not my idea of fun.
I realized that I knew of no good solutions to the issue when I started this conversion but I have learned so much. here on FOG, in the last couple of weeks that I should have known but did not, that I thought it the better part of valor to ask here. I've got a few rather cheesy designs running around in my head that probably will not work. My fallback is to cut on the bandsaw and use a jointer plane to remove the differences.
Alex said:Table saw. I'm not a one-tool-can-do-it-all guy, I prefer the best tool for the job so I can work quickly and efficiently.
Peter Halle said:I hope that you will post what your ideas are. Yes, that does take guts sometimes on the internet and in a forum like this. The Festool trainers mention in their classes about how the tools are used relatively low as to what they can do. There isn't a stupid idea out there in my mind when it comes to using the Festools and the "system." The number of things I have learned here and then did a head slap is enormous.
The Trainers also learn from users of their tools and who knows, maybe you will come up with the next tip and trick they show!
Pretty genius! Sort of what I was thinking about but my thoughts trended to 2 pairs of tracks each pair connected at the sides but sliding to act as the stops - outer tracks anchored by dogs which also act as rail stops. Consider your idea stolen. Thank you very much!TrackTubesGuy said:There's a number of ways to do this, but if you're cutting on an MFT table and using dogs to line up your rail, you just need to use a couple scraps from the same thickness material, cut a 1/4" slot and use some short rail dogs and knobs to have a sliding stop. When all set up, I draw a line and check with a square to make sure it's dialed in before cutting. Very fast and accurate. I've cut the slot on a router before I got my Shaper Origin ... now I have a cut file I can use for different materials. For those of you with a Shaper .. you can fine the file on the Shaper Hub.
