treesner
- Sep 1, 2015
Id like to build a tracksaw table with dog holes for cutting square.
Can I just do a 3/4 or 1" plywood then screw a sheet off hardboard onto that to replace later. Guess I'm wondering if I want to replace the hardboard from all the track saw cuts could I just remove the plywood and hardboard, screw on a new piece of hardboard and use the plywood to quickly drill through the hardboard as I'm thinking its ok of that hole isn't super accurate since the plywood would be the wider part and keep the dogs accurate.
second question, should I make the top as a portion box or just use single sheet of ply?
like the look of this one
