Replacing cam on MFT/3
pugilato
The cam that holds the swinging rail on my MFT/3 broke, so I ordered one (thanks Tom Bellamere). Here is a picture of the new cam installed. The question is, how tight do you make the cam to the back plate? Before I broke it, it seemed like the cam was not tightening correctly... that is, instead of a smooth tightening, I had to push on it hard and them it would suddenly fall into a tight position.
What I'm looking for is a quick and dirty guidance on how tight those screws holding the cam need to be.
While I can't answer your question specifically, Your post has reminded me that mine (both front and rear) are really annoying in that about a third of the way down, will catch, requiring  a lot of force and then will pop past the sticking point with a loud crack. They do this with the adjustment either backed off or tightened down.
  Back to the adjustment, I would say only tightened enough to keep it from moving when in the down position.
In the video where Steve Bace demonstrates sitting up the MFT/3 his guide for tightness is tight enough to prevent the bracket from sliding down when pressure is put on the rail.  Please note that Steve mentions that a little turn of the screw goes a looooong way.
He covers this at about 1:40 in:
I have been encountering the same issue, where it requires a lot of pressure before it suddenly clicks into place.  I tried backing out the bolts, but at the point where the cam worked smoothly, it was too loose in the locked position, so I gave up.  To avoid stressing the plastic piece and breaking it, I have just been reaching underneath, palm facing up, and pushing the rear side up with my fingertips while pressing the front side down with my thumb, and the cam works a lot more smoothly without catching.  Maybe some grease would help as Laminator suggested.  I am going to try that.
You sort of have to lift up on the handle while you lock it down if that make sense
It does make sense, I do it like this to  [big grin]
