Residential window film for IR/heat rejection?
The house we bought in Colorado Springs came with “zombie apocalypse” rolling shades on all the windows and doors. They make a major difference when it comes to cooling the house.
For double-pane glass, does it matter whether the heat rejecting film is on the inside or outside? Outside it can get damaged, but inside it might reflect heat back through the glass and cause the seals to fail, leading to fogging.
I have a couple skylights in my garage workshop that are 30 years old and are fine, but transmit a lot of heat through them. I was thinking of adding film to them, but worried about the double pane seals failing. In my house, with a dozen skylights also 30 years old, one skylight seal as failed and is fogging. Since we need a new roof this summer anyway, we're also replacing all of the skylights. The new skylights have a heat rating of 0.26, which means they let only 25% of the heat through (I can look up the exact term if anyone's interested) since they're both tinted and argon gas filled - so I'm expecting it won't be as warm inside as currently.
But, I'm cheap and didn't want to replace the skylights in the garage (at a couple grand each) so thinking about films and shades. I do like having more natural light in the shop, though, and opening them to vent hot air out is nice, too.
The newer dual glazed windows have IR blocking and work well. You could try to position an awning or a gazebo style structure attached to the house. Heavy drapes or black out curtains work well. Try calling Smith and Noble they make a good product albeit pricey. There might be a solution by applying a window screen that could filter some of the sunlight out. Conversely, go to Home Depot and purchase some potted plants to shade the window as a temporary fix. Then come fall return the plants or winter over. If you’re on a tight budget just take some cardboard boxes and cover the windows during the heat of the day. It might look like a kitchen house but it’s a simple fix to keep yourself from baking in the next 1-2 weeks while you sort things out. Good luck.
I went this route a while back and ended up skipping films altogether after comparing them to Passive house glass I had installed in a remodel. The glass itself blocked a ton of heat and light without needing anything extra, and it performs way better year-round. If you're already doing new windows, skipping films might save you a step and give better long-term results.
